Topic: Fireface UFX: not getting stereo mix out of SPDIF into Mac SPDIF
Hi. Looking for an explanation or routing solution.
Im trying to route Logic Audio which plays out into Hardware input 1 & 2
but route it to AES  left & right and out SPDIF into Mac SPDIF input.
I see in the TM Software Playback on both AES L & R getting signal.
A weird thing is happening in that it seems to be received at the Mac digital input as 2 mono sources,
that are identical. When I fool around with the Hardware 1 & 2 and make them 2 separate mono channels
and take turns muting I see that left or a right side can be recorded..So I'm not sure where the breakdown is
of the stereo mix I'm trying to achieve.
iTunes and other Mac programs that are routed into the Fireface (via cables out of the Mac)
do get recorded stereo thru SPDIF and back into the Mac into stereo....!
Eventually what I am trying to do is play guitar along with Logic directly into Quicktime
to make fast videos. Either with the guitar directly form the Fireface or routed through Logic is fine too.
http://www.youtube.com/c/JohnFindlay
https://www.facebook.com/johnfindlaymusic/
Re: Fireface UFX: not getting stereo mix out of SPDIF into Mac SPDIF
hmmmm! I routed Logic Audio to Fireface hardware output 3 & 4 and then routed to AES digi out into digi in MAc and it works on stereo. Something to do with Logic not wanting to share channel 1 & 2 with something else??
