Topic: ADI 2 Pro usage as a preamp and real time sound processing interface
I'm interested by the coming ADI 2 Pro, to be used as a real time audio processor.
Use case is that I would like to
- connect my turntable (analogue input), TV (optical), Tuner (coax), and Mac Mini (USB)
- process the sound with Dirac Live running on my Mac
- output the result to my active monitors using the balanced analogue outs.
Is this use case supported? I.e:
1/ Does the ADI 2 Pro support multiple inputs as an interface with mixing capabilities?
2/ How the input detection will work in that case? Will the interface switch to the latest active input? Can auto selection be disabled?
3/ Is it possible to route inputs to front and rear analogue outputs separately?
4/ Is TotalMix supported?
And subsidiary question: are IR remotes supported?
Thanks!
