1 (edited by lassea 2016-05-18 21:40:16)
Topic: dim flashes on and off
For some reason the dim function flashes on and off (the sound as well)...
Somebody knows why? It has to do something with the MIDI butI can't figure out where's the problem...
Re: dim flashes on and off
Is my crystal ball defect ? It tells my that you have a Nakamichi OS with a Mercedes Benz recording interface and that you use it for car racings, thanks for an update wink
I think it can not hurt if you could tell a little bit more details. What OS, recording interface and which Totalmix FX / driver version. And I dont't understand from your very terse description how this could be related to Midi. Could you kindly describe your setup ?
Seems like TMFX has MIDI control active and you are playing/sending the MIDI note that enables the DIM function.
aaah ok wink
