Topic: Babyface...AN2: No Choice of Routing
On my Babyface...AN1 is fine and I can choose where to route it. AN2 on the other hand is tinted blue and the routing popout area is blank giving me no chance to hear the direct signal as I can as with AN1. I can still hear the signal coming through to my DAW. What is going on and how can this be remedied? All was fine the last I used it all.
Re: Babyface...AN2: No Choice of Routing
Are you referring to inputs or outputs? What exactly is blue? In any case, a mixer reset should help (in the options menu).
Thank you so much for responding, Daniel. The mixer reset worked like a charm and the second channel is once more available for usage and routing. Blessings.
