Topic: Windows 10 HDSPe multiface 1 not working after wakeup from hibernation
since upgrade to windows 10 I'm experiencing the problem that audio is not working after wakeup from hibernation and sometimes sleep.
it says multiface is connected in the hammerfall settings.
when I uncheck all WDM audio in the Hammerfall settings and turn it back on to analogue 1-8 (multi channel) it works again.
driver version: 4.15
multiface 1 - revision 20
optimized for multi client - on
I'd appreciate help on this issue
Re: Windows 10 HDSPe multiface 1 not working after wakeup from hibernation
Did you disable Fast Start?
yes fast start is disabled.
also just today computer came back from hibernation and everything worked, so it is not easy/reliable to reproduce.
