Topic: ADI-2 Pro: Possible to use Interface & A/D Converter independently ?
For example,
is this recording setup possible:
analog stereo Signal => ADI 2 Pro => SPDIF out => ext. Reverb Processor => SPDIF in ADI 2 Pro => via USB into Mac
Re: ADI-2 Pro: Possible to use Interface & A/D Converter independently ?
Yes, no problem. You can set the unit manually into AD/DA converter mode. The up to 6 input channels are still sent to USB. The return path (USB to analog out) is limited to output 3/4, though.
OK, many thanks.
