Topic: Babyface Pro Yosemite problem
I have been using babyface pro with Mavericks for some time now. I stayed in OS X 10.9.5 because i was afraid of compatibility issue.. now that all my projects have been finished, I upgraded to Yosemite OS X 10.10.5
As I upgraded my OS X to 10.10.5, babyface pro Total mix won't open. Fireface USB settings application opens and it recognizes babyface pro but when i try to open Totalmix, it bounces on the dock and eventually quits itself or i have to force quit it.
Because total mix is not working, i headphone port on babyface pro does not work so is the outputs..
Can anyone help me into right direction to fix the problem?
I installed driver 2.18 when i was in mavericks. I tried to uninstall usb driver and total mix and re installing it after upgrading to Yosemite.  firmware of Babyface pro is up to date.
Thank you very much
Alan
Re: Babyface Pro Yosemite problem
http://www.pro-tools-expert.com/home-pa … o-yos.html
Jeff.
If you were in a same room as me, you could not have stopped me from hugging and kissing you.
It fixed the problem.. how could i have known this solution without your help..
big thanks I really appreciate it.
all the best to you
Alan
youre the man jeff!
