Topic: Feature request: Rearrange TotalMix channel order
I have several groups of different mic pres running into a Fireface UFX -- four API, four Neve, four UA, eight Presonus. Depending on the session, these pres may be grouped differently across vocals and instruments.
It would be so helpful to be able to rearrange the TotalMix channels to reflect the pre grouping per session.
Re: Feature request: Rearrange TotalMix channel order
Did you try to use the Channel Layout feature to make this grouping visible?
3 (edited by jabdo56 2016-10-08 20:30:54)
Matthias -- thank you for your reply. I have used the Channel Layout feature, however, it doesn't help in my situation. Below is an example of what I'd like to do. This would, of course, change depending on the size and configuration of the band.
http://brokenworks.com/images/rme%20totalmix%20layout.jpg
This would be a great feature. Please consider it.
