1 (edited by Jp008 2016-10-13 00:58:28)
Topic: TDIF-1 monitoring with an ADI-8 Pro
Does anybody know if there's a way to monitor in both TDIF and ADAT modes simultaneously on an ADI-8 Pro ? When I switch between one or the other on the front interface, I can only hear either "TDIF" or "ADAT", but not both at the same time.
Also, when in TDIF mode, the only outputs working on the ADI-8 are channels 1 & 2.
Is there any solution(s) for any of this? Some type of switch box or cable maybe ??
Re: TDIF-1 monitoring with an ADI-8 Pro
There is no dual simultaneous monitoring possible, and that is quite obvious.
TDIF supports all 8 channels. You either use a wrong cable, or do not send 8 channels of audio to the unit.
