Topic: Need help remote controlling XTC from TM/UFX+ [Solved: TM FX 1.33]
EDIT: solved by TM FX 1.33, many thanks
EDIT2: sorry, it solves the Remote Control issue, but I can't change routing anymore, or muting of outputs.
Download of .exe: https://www.forum.rme-audio.de/viewtopic.php?id=24390
Please help. I don't get MIDI over MADI to work between UFX+ and XTC.
I am getting input from all Mic inputs 1..8, but things like gain, pad, etc wont be synchronized between XTC and TotalMixFX.
UFX+ driver: 0.9574, HW Rev 39, SW Vers 34
XTC: Firmware 25/47
Clock: UFX: internal
XTC: MADI
Driver settings dialog shows synched to 44.1 kHz, 64 channels
MADI setup:
UFX+: MADI Format: 64, MADI Frame: 96k Frame, MADI Output: Optical
XTC: Delay Comp. Auto-CA, CompensID: 1, Madi Format: 64, Madi Frame 96k
XTC General Settings:
MIDI Device ID: 0 (same as in TM), MIDI Cont. Thru: ON
XTC Digital Routing:
ADAT OUT: Mic 1-8
ADAT2 OUT: Mic 1-8
AES OUT: M 1-8
MADI 1-8: Mic 1-8
XTC MIDI Sources:
Control (Inp.): MADI In
USB Midi 1: OFF
USB Midi 2: OFF
MIDI DIN out: OFF
Midi over MADI: Control (????? unsure)
TotalMixFX: v1.31
Options: Enable MIDI control -> enabled (also required for MIDI over MADI ?)
Settings: AUX Devices:
Device Settings:
Digital Channels: MADI 1-8 (is this correct?)
Device: Octamic XTC
MIDI Settings:
MIDI IN: None
MIDI OUT: None
Device ID: 0 (Same as in XTC General Settings).
Would be nice if somebody could tell me, how I get it to work, many thanks.
