1 (edited by jonathandunford 2016-10-25 19:34:54)
Topic: Gain acting strangely
Today all of a sudden in Totalmix,  I needed to set my left microphone to 48 (Gain) to have the same level for the right at 38 (Gain) =https://flic.kr/p/NqBnBr/
Material RME Babyface PRO.
Microphone Neumann KM 184
Imac Running on Sierra mid 2011- 6 gigs RAM
This was not the case even yesterday.
I changed the cables and the same result.
Any hint of what is going on?
Thanks for any insights...
Re: Gain acting strangely
Just fiddled around some more and changed the stereo phase (more left) up to about L20 then back to 0 and now it all is fine.
I checked the firmware up to date.
Very strange behavior does anyone know why?
Did you enable smth like a PAD on one mono channel ?
4 (edited by jonathandunford 2016-10-25 19:39:40)
No no pad just the usual I posted a screen shot here https://flic.kr/p/NqBnBr
That being said as you can see from the screen shot I set a 12db difference so the 11db from the Pad option may be the problem.
But I did not as you can see click on Pad, so there may be a problem with the software.
As I said by changing the stereo width manually and reseting it back to zero somehow fixed the 11 or 12 db missing from the left channel...
5
If you have this problem again simply toggle PAD Off/On.
Question: are you on the latest TM FX 1.31 or 1.34?
Thanks for the suggestion, just updgraded to TM FX 1.31
Haven't seen the behavior again.
