Topic: Current recommendations for long USB cable solution
I'm running a UC from about 35 feet (extension cable to a relatively cheap powered USB hub) over USB 3.0 to a Windows 10 PC in a machine room.
It's working pretty well. I haven't had any dropouts, but I have had to reset the interface once or twice which I attribute to the cable length.
Is it possible to improve the stability with a better hub, repeater cable, optical cable, USB PCI card, etc.? Curious to hear about what the people at RME use.
ufx ii / bfp
Re: Current recommendations for long USB cable solution
USB 2 Repeater cable with active electronics. Cheap and efficient.
3 (edited by wderganc 2016-12-27 17:44:02)
Do you have a maximum recommended length? (I've seen 10-20 meters)
Edit: this male to female 15 meter cable from SIIG has the option to add a 5 volt power supply to the end of the cable: https://www.amazon.com/gp/product/B0053 … PDKIKX0DER
Or, alternatively there is a 15 meter male to male StarTech that could go from the computer directly into the interface without any additional cables. https://www.amazon.com/StarTech-com-10m … e&th=1
I'm probably going to order the StarTech unless there is good reason not to smile
ufx ii / bfp
I tested only 15 meters. Mine looks more like the Blue Rigger and Monoprice one. The additional power input can be useful, but is of no use in your case.
5 (edited by wderganc 2017-01-02 18:18:29)
Thanks for your feedback Matthias smile
ufx ii / bfp
I have had very good success with USB over Ethernet.
Sounds expensive! Is latency workable over really large distances?
Figured I'd update on the cable -- the 15 meter version I linked works great smile
It's working no differently than a short cable. For me, the "tells" were drivers crashing when switching sample rates (open a program @ 96K when something is already open and playing 44.1) and much less noticeable, the DAW would only see a limited number of channels (14 in 14 out) instead of the full 18 in 18 out when using a long passive cable.
ufx ii / bfp
It's pretty cheap.
The powered USB cables I tried didn't solve my problem. That may have been because I was using a USB female to male wall port to get the USB signal into the closet where I keep my computer. As soon as I replaced most of the run with Cat6 cable, no more problems.
I was also getting lost connection whenever the sample rate changed.
9 (edited by Manuel 2023-08-23 13:43:53)
Hi MC, I'm using a passive 10 m USB 2.0 cable with my UCX II at 192 kHz and the lowest possible buffer size, and I'm not getting any errors at all. Am I being lucky?
I looked into 10 m cables with a USB repeater built in but the ones I could find all have the repeater at the very end of the cable like the ones you guys linked earlier in this thread with Type-A USB 2.0 female connector. I see why I would want the repeater on the end if I am connecting a cable to it, but then there are Type-A male to Type-B female cables like the one I got that connect directly to the audio interface, in which case the audio interface acts as the repeater, correct? I think the repeater is useful for lengths > 10 m, even if the USB 2.0 spec says the max passive lenght is 5 m.
