> I guess it really depends on how you use snapshots.
> I use them to recall routing options to various hardware, whereas you seem to use them for control room options
Yes exactly. More precise, I use it for BOTH ... therefore careful how to implement it
> the way I see it, the control room options are more elegantly handled 'only' by the actual control room section of TM,
> and so the way I see it 'all' control room options should be outside of snapshot recall (mono, mute, volume, speaker B etc)
> I would like the option to have "ALL control room functions ignored by snapshot" or
> "ALL control room functions recalled by snapshot" in the preferences,
> rather than just Main out volume being ignored or recalled
I would not suggest to implement it as a global configuration option in TM's preferences.
This could have too many implications:
- from user perspective: which way to go before starting to spend much work defining snapshots and workspaces
- from programmers perspective: too much impact on code basis and config file formats.
I would implement this as kind of a filter, to filter out, what control room settings shall be ignored
when changing snapshots. I.e.:
- 1 additional Button: to activate or deactivate this filter.
- 1 additional Button: to get a pop-up menue to select what to filter out (volume, speaker B, dim, etc ....)
I would place these 2 buttons maybe to "View Options":
Separator: "C.Room Filter"
Button1/2: "Define" "Enable"
Or alternatively the definition of Filters under TM Options and only one Button to enable / disable.
