Topic: Brain storm: controling TotalMix with midi or an other way, importan..
I need your contribution to find a solution for my problem.
First of all; I have UFX and M-Audio Code61 midi interface.
1. I would like to enable phantom power for my mic inputs and switch instrument hi-Z ; but unfortunately as a blind user, these are not possible on TotalMix by using Screen reader.
2. I decided to buy ARC, but it seems that it will not activate phantom, and also it will be available in end of the March in our country.
3. I reported that to RME add these function to key commands dialog box, but there is no changes sinse end of the 2015 yet.
My questions are:
1. Is it possible to control TotalMix with my M-Audio Code61? ı know that it uses Mackie protocol.
2. As a brain storm, do we have any way to set above settings?
3. I downloaded TouchOSC to my iOS device, is it possible to use it for above settings as well?
4. all comments and thoughts would be awsome, maybe we can find an other unexpected solution?
As you see, I'm trying to find a way to use my UFX; but it seems that RME forgot blind musicians.
I'm really good at xCode, .net and visual Basic, but can't use TotalMix!
I'm good at Cakewalk Sonar, Samplitude X3 Suite; but can't use TotalMix!
I can reformat and install my Windows and MacOSX based computers without help; but I can't use TotalMix!
I'm working at Apple; but can't use TotalMix!
Any thoughts?
Thanks in advance.
