Topic: UFX / UC + USB C / Macbook Pro 2016
If i use my UFX or UC with the new MacBook Pro I either have to connect it before turning it on, or first plug the USB C side in and then the USB B side. Otherwise it won't connect/sync with the computer. Same behaviour with both interfaces. All other devices/interfaces work as usual. I tested the USB C / A Adapter and two USB C USB B cables. So it looks like this has something to do with the RME gear. Is there anyone experiencing the same issues? Or are you at RME familiar with that and there might be a firmware update to get rid of that behaviour?
