Topic: UFX+ Analog input value
I have just changed my Fireface UC for an UFX +.
I have a question about the values of the analog input.
In 44,1khz I have 105 and 192khz I have 68.
http://img11.hostingpics.net/pics/236149IMG6191.jpg
We see the modulation on the screen and in the total mix. The level is blinking.
that's the same in USB & Thunderbolt.
SN : 23770487
Last firmware and driver on board.
Is it normal?
Re: UFX+ Analog input value
The screen from the UFX+ in 192khz
http://img11.hostingpics.net/pics/394414IMG6190.jpg
Thanks.
It is normal and explained in the manual...
Ok, that's the chapter 39.7 ?
in total mix i have -105 at 44,1khz , -95 at 96khz and -68 at 192Khz.
5
Set the meters to display RMS level.
6 (edited by hugo.donuts 2017-02-07 17:36:27)
when i turn on the RMS meter i have
44,1khz -114
96khz-105
192Khz -78,5
on the analog inputs.
here the pic in 192khz
http://img11.hostingpics.net/pics/970683Capture.png
And i have read the chapter about the noise level.
7
Perfectly normal then.
I think what you're seeing may be the ADC noise shaping, they just move the noise above audibility:
"For applications where a full Nyquist bandwidth is not needed, alternate ADC architectures can be implemented. Band-pass continuous-time sigma-delta (CTΣΔ or CTSD) ADCs use a noise shaping function that essentially “pushes” or filters the in-band quantization noise out of the frequency band of interest (Fig. 3). This causes the noise transfer function to have a non-flat shape that is notched lower over a narrow band of interest, smaller than the Nyquist bandwidth. In this band, the CTSD ADC operates to its maximum performance where the SNRFS is the highest (Fig. 4)."
Scroll down to figure 4:
http://electronicdesign.com/adc/noise-s … adc-metric
I understand ! See the screen blinking made doubt at the beginning.
thanks again for your help.
And it's important to note, -80dB at 81kHz is superior to the best analog tape recorders that barely hit that noise figure even in the audible band.
Anybody here remember tape hiss?
Hi hugo.donuts. Can you please tell me how you posted a pic onto the forum??
I can send donuts??
SN : 23770487
Is it normal?
12
Yes.
