Whats your budget ?
The AIO delivers to you:
- Analog IN : 2 channels (requires other cable for servosymmetric inputs)
- AI4S-192 AIO : 4 channels (expansion board with servosymmetric inputs)
- ADAT IN : 8 channels with a preamp
- Analog OUT : 2 channels (requires other cable for servosymmetric outputs)
- AO4S-192 AIO : 4 channels (expansion board with servosymmetric inputs)
- ADAT OUT : 8 channels with a preamp (if it has line OUTs and supports routing to those from ADAT)
(- Phones OUT : 2 channels which I would leave for phones)
Assumed you will get a preamp which delivers to you via ADAT 8 channels IN and OUT,
then you require only the AI4S-192 AIO card, the other breakout cable to get:
- 14 analog channels IN
- 10 analog channels OUT
Which does not fully match your specification.
https://www.thomann.de/de/rme_hdspe_aio … O_220433_0 €579
https://www.thomann.de/de/rme_ai4s192_a … arch_prv_0 €164
https://www.thomann.de/de/rme_bo9632_br … H_164831_0 €58
So in this case you have to pay €801 for a solution which does not fully match your expectation,
as 2 analog inputs are missing.
And you have to handle (plug / unplug) analog input and outputs at 3 different locations:
- on a breakout cable connected to AIO
- on an expansion board connected to AIO (2nd PC slot)
- on an externap Preamp
If I were you I would look to simplify the setup. What about getting a RayDAT and connecting 2 Preamps via ADAT ?!
https://www.thomann.de/de/rme_hdspe_ray … T_208766_0 €585
This could bring to you 16 inputs and 16 Outputs with either 44.1 up to 96 kHz sample frequency.
In terms of cabling you can use up to 15m ADAT cables.
You can start even with only the main RayDAT card in your PC, so that you even only require 1 PCIe slot.
This gives you already 2 ADAT IN and 2 ADAT OUT, where you can connect 2 Preamps @44.1/48.
But if you have the slot position free, directly mount the daughter card which is included, then you have 4 ADAT IN and OUT.
In terms of cabling to achieve 16 analog IN and 8 analog OUT @44.1/48 you require only 3 ADAT cables.
