Topic: ADI-2 Pro .. Quick A/B change for 2 different settings
Hi Matthias,
would it be possible to implement the possibility to quickly change between 2 different profiles ?
One example use case:
I have i.e. 2 different headphone setups:
1) neutral settings for phones 3/4 for mixing and mastering
2) more HiFi settings with intelligent Loudness, cross-feed, ....
When doing mixing / mastering I would like to quickly change between these two.
As the knobs have already many functions I would propose to add a new display type for this A/B comparison
+-- Display --------------------------------------------------------------------
1st  Line: <select Profile A> (When turning, Encoder 1 toggels between the 9 user profiles)
2nd Line:     <select EQ profile for A> (When turning, Encoder 1 toggels between the different EQ profiles)
3rd Line: <select Profile B> (When turning, Encoder 2 toggels between the 9 user profiles)
4th Line:      <select EQ profile for B> (When turning, Encoder 2 toggels between the different EQ profiles)
Status Display, which Profile is not active A or B
Bottom Line: like Black/White Modus
Pushing the Volume Knob shall toggle between the dialed-in profiles / EQ profiles.
What do you think about that ?
I think this would be a very useful additional feature for Studio Pros and for listening.
BR
Ramses
X10SRi-F, E5-1650v4, Win10Pro20H2, Cub11Pro, UFX+ (v0.9735), XTC, 12Mic, ADI-2 Pro FS R BE
Re: ADI-2 Pro .. Quick A/B change for 2 different settings
We have a different solution that will adress this, and hopefully is already available with the next firmware update.
Remap Function Keys now addresses this request. Simply assign one Setup to one key, another Setup to another key.
https://www.forum.rme-audio.de/viewtopic.php?id=25454
Many thanks will try after my trip.
BR
Ramses
