Topic: Digiface 1 + HDSPe Expresscard – installation problems
I try to install a Digiface 1 and a HDSPe Expresscard (second hand ebay …) on my Dell Latitude e6430 with Windows 10. I’ve tried different drivers, but it always install the Multiface and not the Digiface (it shows 8 Adat in/out, 8 analog in/out, SPdif and speakers in/out in the windows control panel and in RME softs), and the Host Error Led stays red on the Digiface.
What’s wrong ? Help please ! Thanks
Re: Digiface 1 + HDSPe Expresscard – installation problems
Did you check the firmware for the ExpressCard? You can try a different FW400 cable, but the problem can be in the Digiface or the ExpressCard. Not easy to find out without using known-good components to swap.
Thank's Jeff
I've tried an installation with an other FW cable, and ... it works ! At once with cubase and the Asio pannel, but with windows showing Multiface in and out (8 analogues in/out).
But today, I've installed Digicheck, and now all the menus shows the 26 tracks Digiface in and out in windows pannels, and in Cubase Asio Pannel.
Thank's for your fast response ... and sorry for my "not too good" English ;-)
Christophe
