Topic: HDSPe AES not discovered in Windows 10
I've had my AES card for about a year now. It was working fine in my Intel 5820K/Asus-X99A computer setup. I purchased a new AMD Ryzen 1700x setup, and the first motherboard I tried was the Asus X370 Pro on Windows 10 Professional 64 bit. It did not recognize my AES card in Windows *at all*. There was no trace of it in Device manager or the sound control panel. Even after installing the latest driver. I RMA'd the motherboard, thinking it was faulty, and rebuilt the computer today using an ASRock Killer SLI/ac board. Same problem, no trace.
Pretty sure the card still works, it was running just a couple of days ago in my Intel setup. I also have a Babyface Pro that installs just fine (and did for either AMD motherboard).
RME support asked me to check the BIOS to make sure that any PCIe sleep functions were disabled but I didn't see anything like that in either BIOS.
The only strange thing that I noticed is that when I went to install the latest RME drivers, it would install extremely quickly, if not instantaneously, and then afterwards Windows would prompt me that "Maybe that didn't install quite right, would I like to install it using a compatibility mode?". Even if I click yes, it doesn't solve the issue.
I did poke through the menus in Device Manager and scan for hardware changes. No detection. If I choose to install a "legacy device" in the Device Manager I can select an RME HDSPe AIO from the Microsoft menu (which should have the same driver as the AES), but when I select that option, windows immediately goes to a Windows crash screen and tells me it will collect information on the problem and reboot. The file at the bottom of that crash screen seems to indicate a problem with something similar to hdsp.sys
Does anyone have any ideas, why not only one, but two motherboards cannot see my PCIe card? I had literally zero issues with this thing prior to the build.
