Topic: DSD stream indicator
When playing DSD256 tracks we see on the ADI screen 705Khz. It is normally? Last firmware and driver installed.
Re: DSD stream indicator
Sure. As described in the manual.
Just to be sure I understand correctly, the input DSD signal is then converted internally to PCM? Always?
thanks
Not if you activate DSD Direct.  --> Manual...
