Topic: FF400: assign SPDIF IN to one offirst 8 ASIOin rather thandefault 9-10
I´m using Fireface 400, via ASIO, with Asio Link ODEUS. The later that can read only the first 8 ASIO Input of the Fireface. Is there anyway to assign, maybe with total mix, the SPDIF IN of the fireface to the first 8 mono asio inputs that fireface asio driver shows to other programs, rather than the default one, the 9-10 asio input?
Thanks in advance.
Re: FF400: assign SPDIF IN to one offirst 8 ASIOin rather thandefault 9-10
Your card has a loopback function somewhere, it can loop back any output to an input. You can loopback the channel you are playing the spdif on back to any input. Make sure the faders of both the spdif playback and output are at 0db and nothing else is outputting to that output.
