Topic: Make headphone mix identical to main mix
I've been using Totalmix for a long time and there's one thing I just don't get. In most situations I want my headphone mix (at least one of the two available in the FF802) to be identical to the main mix. I don't use the headphone outputs for the musicians' cue mixes. So for example in a recording situation I just want to be able to mute my speakers and to listen to the same mix via headphones.
But somehow this seems no to be possible with Totalmix. Instead I have to manually position all input faders in the headphones submix so that they mirror the main mix.
Am I missing something? Is it possible somehow to make the headphone mix automatically mirror the main mix?
Re: Make headphone mix identical to main mix
I would say .. you can not digitally store gain settings like with UCX, UFX* (as you have Gain and Volume potis.
But you can store the routing and simply dial in with the potis the volume that you require.
Assign Main Out as -> Analog 1/2
Assign Phones 1 as -> Analog 9/10 (if I remember right)
Assign Phones 2 as -> Analog 11/12
Use submix mode.
Click to Main Out channel, create a submix to Main Out by raising Input and Playback faders for this output channe.
Save this to Snapshot 1
Click to Phones 1 channel, mute Main out, make submix for this output channel.
Save this to Snapshot 2
etc ...
Explained here:
http://www.tonstudio-forum.de/blog/inde … teps-DE-E/
http://www.tonstudio-forum.de/blog/inde … al-Videos/
Or just feed your Phones from your "Speaker B" in the Control Room?  You can also "Copy Submix" and apply to the Phones output.
cool
2x SSL Alphalink MADI AX
Right click "Copy/Mirror Main out" and right click "Mirror of Main out" on the Phones. Easy!
Oh sorry, then I misunderstood the question.
Wow, this seems to be what I am looking for. I've found it in the manual now but I have to say it's pretty well hidden! Gonna try this next time I am in the studio.
