1 (edited by regisplanque 2017-05-22 08:32:44)
Topic: DSP based EQ with totalmix for Digiface USB and HDSPe Raydat
I own a Babyface first generation.
With the Babyface and TotalMix I am able to use hardware based EQ on the input and output channels
It is not clear if I could do the same with the Digiface USB or with the HDSPe Raydat?
My goal is to have a DSP based ADAT mixer with very low latency for multiple headphone monitoring =>thus including DSP based EQ for inputs and outputs
Will I be able to do this with the Digiface USB or HDSPe Raydat?
Thanks!
Re: DSP based EQ with totalmix for Digiface USB and HDSPe Raydat
Both no.
Ok.
which one should I use then? I cannot use my Babyface because I need more than 8 ADAT inputs.
4 (edited by EvilDragon 2017-05-22 09:36:06)
UFX/UFX+/UFX II have twin ADAT ports, which gives you 16 ADAT inputs.
A very happy RME UFX+ & ARC owner smile
Okay! That's a bit more expensive ....
Thanks for your replies
On the other hand you will get so much more ..
