1
Topic: 9632 sound
Hello folks,
I've been using a mixer with my setup, however, I decided to just go direct from my keyboard to the sound card but I can't get levels high enough to record. I used both tools that come with the sound card but just can't get louder levels. Any suggestions?
2 (edited by ramses 2017-05-25 05:38:04)
Re: 9632 sound
Change the Output Level in TotalMix FX, the card supports 3
See also chapter 24.2.
DA – Line Out
• Auflösung: 24 Bit
• Rauschabstand (DR): 110 dB RMS unbewertet, 112 dBA @ 44,1 kHz (ohne Mute)
• THD: < -104 dB, < 0,00063 %
• THD+N: < -102 dB, < 0,0008 %
• Übersprechdämpfung: > 110 dB
• Maximaler Ausgangspegel: +19 dBu
• Frequenzgang @ 44,1 kHz, -0,5 dB: 1 Hz - 21,1 kHz
• Frequenzgang @ 96 kHz, -0,5 dB: 1 Hz – 43,5 kHz
• Frequenzgang @ 192 kHz, -1 dB: 1 Hz - 70 kHz
• Ausgang Line: Cinch unsymmetrisch, optional XLR symmetrisch
• Ausgangsimpedanz: 50 Ohm
• Ausgangspegel: Hi Gain, +4 dBu, -10 dBV
• Ausgangspegel bei 0 dBFS @ Hi Gain: +19 dBu
• Ausgangspegel bei 0 dBFS @ +4 dBu: +13 dBu
• Ausgangspegel bei 0 dBFS @ -10 dBV: +2 dBV
