Topic: Re order input channels
Hello all,
So, I have recently set up a patchbay w/ 1-8 mic pres patched into the 1-8 inputs on the UFX.
I have total mix set up kick-1, snare-2, toms-3&4, oh-5&6, and so on.
Since I have added the flexibility of the patch bay, of course I want to try different
Pre amps on different channels.
Is the total mix layout always inputs 12345678, etc., starting from the left side?
I want, say, analog input 8 to be available in channel 1 on the totalmix so as to keep things in order visually.
Let's say, I can drag different channels in my daw to group drums and the inputs will follow.
Is this possible in total Mix?
Hopefully I explained this well enough to warrant an answer.
Thanks,
Randy
