Maybe I know now why.
Could it be the case that you are using 2 different RME products in your PC
- RME HDSPe AES and
- RME Multiface II
additionally the 2 Rosettas ?
Then you would have in total 4 devices which need to be synchronized.
Then it would make sense to have an additional AES tab in the RME driver settings dialog.
On the screenshot I see: "AES (1)" and "Multiface (2)"
This you didnt communicate in the description of your setup not very well and
confused me why you talked about settings about AES.
Normally I regard AES simply as an I/O channel on a card not an interface itself.
So you have 4 devices to be synchonized.
Then I would eventually use the AES Card as Clock master since this seems to be the newer card
and there you have connected your main monitors you said.
Its a good strategy to take an RME device as clock master and the main device which will get clock changes,
usually the device where your main outs are connected to. As it might be a PCIe card, it will also be the more
modern card compared to the old Multiface II. Maybe also the version of steadyclock is more modern on the
newer card (potentially already steadiclock v2).
So set the RME AES to clock source internal and
Multiface II: set clock to WC.
2 x Rosettas: set clock to WC
steadyclock v1, v2 and v3
