Topic: Defective Hammerfall HDSP 9652 PCI???
Hello everyone, I purchased a second hand Hammerfall HDSP 9652 PCI card with AEB4-O. Currently I am in between interface upgrades, and I had head such great things about RME's readability performance, considering I already have outboard and external converters I though I'd try one of the PCI cards (I have 2 pci slots on my mother board).
Anyway after attempting to get everything routed, I believe that I was sold a defective card. The unit seem to have trouble (pops, clicks, intermittent locking, and sample rate sync issue) when attempting to sync to any master device at 88.2 and most notably at 96khz. 41.1, 48 all seem to work, but when selecting 88.2 and 96, I get all kinds of errors.
- I have custom Ross Martin PCM4222 X2 for my primary AD
- I have a apogee Rosetta 200 as my DA
- I also have a M-Audio Profire 2626 I wanted to use for additional ADAT channels
I have tried syncing the PCM4222 as the master clock to the 9652 with spdif, and spdif out of the 9652 to my rosetta 200 for playback. Every other sample rate works fine, but when switching to 96khz I get intermittent lock/no lock error where the 9652 'SyncCheck' readout shows "SPDIF In" bouncing between "Lock" and "No Lock" every few seconds or so. Also at the same time in the Hammerfall setting window the "Sample rate" header blinks red, while the the phrase "current 88200 hz" also blinks to the right of the sample rate window. I get similar issues with 88.2.
With that same setup with the Spdif signal being sent to the Rosetta 200, there is an erratic blinking of the rosetta 'narrow wide' light (this light normally stays solid and indicates if the unit is synced properly). The rosetta sample rate selection lights also flickers erratically between 44.1 and 176.4.
I have tried slaving the 9652 to the rosetta 200 and the profire 2626, to rule out my Ross Martin 4222 AD as the culprit. The results with my other two interfaces were similar, the 9652 will not sync properly to the rosetta at 96k, and the profire as the master also had a gamut of errors relating to sample rate switching.
I've tried slaving the 9652 using different methods: coaxial spdif, adat/optical cables, and bnc wordclock cable. No configuration works as expected with 88.2 and 96khz, except when the 9652 is set to internal.
When both the coax and adat cables are connected going from my PCM4222 AD, and both coax and adat cables going of the 9652 out to rosetta 200 as DA (the 9652 set to ADAT, I successfully select 96khz and can play audio through a media player at 96k, but when opening my DAW (presonus Studio One 3.5) I still get playback and system errors such as complete loss of system wide audio when switching sample rates. This type of error requires a reboot to restore the 9652's playback.
I've tried numerous combinations of settings, different cables, updating firmware, trying older drivers, removing all daughter boards, re-seating in the pci slot, none of that made any difference. The unit only works as I would expect it to when set to it's internal clock. I have not had any sync issues with the other gear involved.
Does this sound like the this 9652 card is defective? Or is there something else I am missing?
