Topic: HDSP 9632 - Z270 mobo & AES splitting questions.
Hi.
As per the title I have a couple of questions about my 9632 that has served me fantastically over the years. Hopefully someone can help!
1. I'm about to retire my aging Q9450 system and finally upgrade to an i5 or i7 system. I want to continue using the 9632 and have found 2 Z270 motherboards that come with PCI slots. ASUS Prime Z270-K (2 slots) and an MSI Z270 PC Mate (1 slot).
Am I safe to assume the 9632 will work fine on these boards? I have read other forums suggesting the use of a PCI to PCIE adapter card but that gives mounting issues, if I go for a mobo with no PCI slots, so I'd rather go standard PCI if possible.
2. I have a pair of Genelec 8250's. Currently being fed balanced analog from the 9632. If I buy a BO968 breakout cable I believe I could then go AES digital into the Genelecs, but I would need to split the AES output from the 9632 into 2 cables for Left and Right. Is this possible? I can't seem to find any definitive information on whether splitting the cable would work. Would going digital into the Genelecs improve sound quality in any way to make this worthwhile doing?
Appreciate any help offered, thanks!
