Topic: Hammerfall DSP Settings program won't open
I'm having a problem where the Hammerfall DSP Settings program runs as a background process, but the window/application won't open when I try to open it. I tried running as administrator and in various compatibility settings with no luck. The problem started after I had swapped out my multiface II for an old multiface I, found that it didn't work, then swapped back to the Multiface II.
