Topic: Octamic XTC as A/D converter
Hi everybody,
I would like to use my XTC as converter, using some external analog preamps.
Is it enough to put the gain on 0db? or should I also use the PAD/INSTRUMENT setting?
What's the best option, in our opinion?
Thanks in advance,
Marco
Re: Octamic XTC as A/D converter
Gain at 0 should do. It will help to compare your preamp's output specs to the XTC's input specs.
