Topic: UCX FireWire High Sierra Driver question
Will there be an updated driver for the UCX Firewire Series? I am currently unable to run the UCX on High Sierra. If there is a workaround that would be helpful as well
Thank you,
Re: UCX FireWire High Sierra Driver question
If that is a new installation then you need to manually enable the driver kernel extension as described here:
https://developer.apple.com/library/con … index.html
Unfortunately Apple's description seems incomplete as the warning/notice dialog does not appear during driver installation :-(
