1 (edited by matzefranz 2017-10-01 14:50:26)
Topic: EQing for monitor mix
Hi There,
I think this is kind of a newbie question, but since Google wasn't much of a help, I going to try it here...
Is it possible to have different eq settings for one input on several outputs?
What I want to do is:
I want two different eq settings for a stereo signal on input 1/2 of my fireface ucx. one setting for the headphone out, and one for the main out. right now, when i turn on the eq on input 1/2 it is global on all outputs. Is there a way to make this behavior independent?
thanks for your help!
2 (edited by ramses 2017-10-01 15:08:54)
Re: EQing for monitor mix
Route the stereo inputs to both outputs, then use the EQ of each output.
If you need help with routing, then work through my primer here:
http://www.tonstudio-forum.de/blog/inde … rnal-equi/
Or also look at the RME tutorials on youtube:
http://www.tonstudio-forum.de/blog/inde … al-Videos/
3 (edited by matzefranz 2017-10-01 16:59:48)
thanks for your reply!
the thing is, I don't want to eq the whole output. Just the input, so that other things that go through the same output aren't affected by the eq.
See it like this: I want a monitor mix at the headphone out, and I want a FOH mix at the main out, which is completely independent from my monitor mix (not just the levels but also EQing of every single input channel).
Use loopback interface
