Topic: ADI-2 Pro: Cannot select multichannel mode
When I am in setup the Stereo choice is fixed and cannot be changed. I have it connected to a MacbookPro 2017 and also an external adc (burl) thru AES as masterclock. The displays reads SRC:AES. I've tried DigitalThru & USB mode (as well as SRC:INT) but the multichannel mode remains unavailable. I have the latest firmware and the device was bought new a couple of weeks ago.
Thanks!
Kind regards
Peter Hansson
2 (edited by ramses 2017-10-14 13:53:41)
Re: ADI-2 Pro: Cannot select multichannel mode
CC-Mode can only be changed if the device is not connected to a computer via USB.
Simply unplug the USB cable, then you can change it from "Stereo" to "Multichannel".
You find the settings under: Setup -> Options -> Device Mode
Thanks! It works now smile
/p
