Got the adapter and started testing and was able to get some sound! very choppy and buggy... a few blue screens on the way but actually heard some sound after many many years. Can't get a proper clean play of anything and the system is going crazy but i feel like there should be a way to get this done.
I want to ask and see if i am indeed running the right setup and see if there's a way to actually get this to work properly.
On my Windows 7 system I have installed and running:
Driver:
RME hammerfall DSP - windows WDM and ASIO 2.3 - version 4.21
Consul:
RME Total Mix FX: HDSP Multiface (1)
My settings are:
Windows sound consul set default to: SPDIF (RME Hammerfall)
Hammerfall DSP consul under the first tab 'Multiface 1' -
Buffer size 256
WDM Devices: Multi Channel
Sample rate: 44100Hz
Clock Source: Internal
worth mentioning: in the 'I/O box' section the options are 'Disconnect' and 'Multiface II' which is not what I have but still produces sound when checked..
Tried playing around with all these options but nothing fixed the choppiness...
your help is highly appreciated!
