Topic: ARC USB and Logics Controller Assignments
If you want to use ARC USB on a system running logic you have to do the routing in logics environment to prevent that the midi data sent from ARC USB messing up things in logic, so far so good, but...
the controller assignments in logic sitting before the environment, so when i use the learn dialog in logic to assign a hardware controller to a parameter in logic ARC USB is still there and because of it's constant midi data flow it places itself as the device i want to connect with the parameter
The only solution i found so far is to unplug ARC USB then learn the controller, plug in ARC USB again, go to environment and do the routing again
When you are using external controllers a lot it's really annoying and totally breaks the workflow.
Is RME aware of this problem and is there any solution to this?
Re: ARC USB and Logics Controller Assignments
Did you already try this:
https://www.forum.rme-audio.de/viewtopic.php?id=25586
Audio AG Support
yes, but logics controller assignments are before the environment, so this doesen't help
