Topic: Could a PCIe riser affect the rayDAT performance?
Hello!
I´m now convinced on getting a rayDAT card. I´ve already mentioned here in the forum that I would like to fit it inside a S4-NFC mini ITX Chassis and I want to post this picture for you to see :
As you may see , the rayDAT would have to be fitted using a PCIe x1 Riser , am I right? Cause it has to be fitted horizontally and not vertically as it should normally do...
Now the question is... Could this affect the overall performance of the card? could it add latency? Could it even dont work at all?
If it works... Which riser do you recommend to me? Brands? models?
Also... Could the card be affected by the heat inside the chassis?
Thanks!
