Topic: Audeze balanced wiring
Hi there, I`d want to give the ADI a try for my Audeze LDC X. Today I`m using 4 pin xlr cable made by Portento. I assume each 6.3 mm jack uses the hot pins for balanced drive, leaving the mass open, but what about polarity, detemining the correct phase?  I checked the site but didn`t find a wiring scheme for the balanced headphone connectors. Where do I find that detail?
Thanks in advance for your support!
Matthias
Re: Audeze balanced wiring
In the manual...
Thanks...now found..well documented..-:) Good support! Ordered a unit to try with the Audeze..
