Topic: [UC] How to turn on/off Direct Monitoring in TotalMix FX?
I am running a speaker calibration stand-alone software (not inside the daw) and it is asking to make sure Direct Monitoring is turned off before starting the calibration. I don't know how to turn it on or off. Any hints?
Thank you in advance.
Re: [UC] How to turn on/off Direct Monitoring in TotalMix FX?
Direct monitoring is off by default. You have two easy options to ensure the input monitoring is not active. Options > Reset Mix > Straight Playback will set the mixer back to a default state. Or you can completely disable the input monitoring by switching modes. Options > Operational Mode > DAW mode.
