1 (edited by explodingPSYCH 2017-12-26 23:39:14)
Topic: RME UFX (USB) under performing (vs Midas Venice F32)
I've been trying to add a RME UFX (not II) to my set up and I'm having some issues with getting it to perform as well as should be expected.
I can't get buffer sizes below 512 to work without glitching. When using the DAWBench files (with Reaper) I am unable to get it to perform any better than my current AD/DAs, a Midas Venice F32. (During all my tests my CPU eventually spikes at 100%, though I haven't been able to push pasted about 40% on my RAM, and usually not even that)
I'm very suspicious of my USB/Drivers/Mobo/CPU. Both units seem to be "maxing out" at the same place, which makes me consider the possibility of a bottleneck.
I use a lot of USB devices, so I've plugged in the RME by itself with nothing else plugged in (Except a mouse and keyboard into an PCI usb slot) while using a one meter USB cable. This has yielded no improvement.
What can I do to troubleshoot my system to ensure that the RME UFX isn't being negatively effected?
EDIT: I'm not sure how this relates to actual performance out comes, in terms of the buffer size I should be able to get without glitches, but for reference, here's a graph comparing the two units, Venice F series getting a just over a 4 rating, the RME getting just over a 7 rating)
https://drumsandelectronics.files.wordp … -42-am.png
System:
intel core i7-4790k CPU @ 4.00GHz
32 GB of RAM
Windows 10 64-bit
various SSDs
Re: RME UFX (USB) under performing (vs Midas Venice F32)
Please run LatencyMon to check if you have any general problems on the PC.
https://www.forum.rme-audio.de/viewtopic.php?id=8933
No Problems detected. Everything is in the green and it says that my system is suitable for handling real-time audio.
https://drive.google.com/open?id=1C1MPW … HhVIp3cn4l
Actually, after leaving the program on for a couple hours, this is what I came up with.... This wasn't my typical work flow, but I'll test it under normal circumstances tomorrow...
https://drive.google.com/open?id=1UBW5Y … R9TERgltg5
5 (edited by ramses 2017-12-28 17:33:22)
Doing a LatencyMon test run is the best we have currently to get a 1st impression, whether a system has load problems that can impact audio.
But most people have no experience how to use this tool. Without this knowledge the measuring results can be completely meaningless.
Please allow me therefore to give some explanations
- why we can get audio problems
- how LatencyMon can support us
- how to use it
- how to report the results to the public
This is a little bit long I know .. but otherwise I fear, that we get only meaningless values of poor quality.
Reasons for audio outages
If you get audio outages the reason is, that the CPU was not quick enough to
- transport audio between recording interface and application and vice versa
- to process audio inside the DAW
Windows is not a real time OS
One thing you should always think of ...
Windows is not a real-time operating system (also not Mac OS X) !!!
Process scheduler and its limitations
A process scheduler tries to handle the different programs on your system as best as it can. But when it comes to the execution of hardware drivers they have the highest Prio on a system andneed immediately to be executed. They can not be interrupted by the process scheduler.
So if there is a time critical job to transport or process audio and the process scheduler assigned a CPU core/thread to this audio process where such an interrupt  service routine is being executed, then the audio related process has to wait until the driver gives the CPU free.
Potential issues on driver level
If the driver doesn't follow certain programming conventions to give the CPU free then this can become a major problem in your system, when you use very low ASIO buffer sizes and in combinations with a loaded system. Where system load can be a combination of CPU load, interrupt load, I/O load (disk i/o). All this load piles at the end up to a likeliness, that your system can not process audio in time without raising ASIO buffers to much higher values.
The best Audio System is
So the best audio system is a system
- with good drivers (following certain programming conventions not to block CPU for too long)
- with all hardware/drivers being disabled which are not required (to reduce interrupt load and likeliness that CPU becomes blocked by low level routines too often)
- where no (or as few as possible) background jobs are being executed while you do audio processing
- with many CPU cores so that the program / driver load can distribute over more CPU cores
- but IMHO not too many cores so that it still fits for applications which need a high single thread performance
- enough DRAM
The purpose of LatencyMon is now to support us to detect
- how quick your system can respond to a test workload of LatencyMon
- to display how many time is being spend by the different drivers
- an ample function whether a system is able to handle audio well
Careful interpreting "LatencyMon's" Ample Function "your system is suited to process audio / or not"
One word to this ample function upfront. Even if LatencyMon shows "green", this does not mean that your system is really well suitet for processing audio. LatencyMon alarms when there was a peak of around > 1000 microseconds.
It is already bad, if you can see, that your system has a very high base load.
Not high enough to exceed LatencyMon's triggers, but still bad enough that you need to adjust ASIO buffer to higher values than you might want or expect.
How to use LatencyMon
1. Run it on an IDLE system (no started applications, no mouse movement as this also generates interrupts)
2. Let it run for at least 10 minutes to get a 1st impression
3. look at the values for
- Win7: kernel timer latency [microseconds]
- Win8/10: interrupt to process latency [microseconds]
There is no display of min or average values, so you need to instantly watch these number and need to make some notes on paper about
- min values
- typical average values
- recurring peaks
Absolute peaks the tool reports to you one line below.
Especially interesting are the min and the typical average values.
1st shows you whether your system is very agile.
Too high values here show 2 things
- most likely energy saving in the BIOS adds too much latency, this could be optimized
- too high process and/or interrupt load
How to treat the LatencyMon results after stopping the report:
1. copy/paste the report results to a file. Ctrl-C copies the report to a copy buffer.
2. Make a screenshot, preferable when LatencyMon shows the lowest values
    to see what the best values can be on your system.
    Screenshot to dropbox -> post it on forum
3. look at drivers tab
- make the columns narrower that you can see
-- ISR count
-- DPC count
-- Highest execution time [ms]
-- Total Execution time [ms]
4. Sort for Highest execution time
5. Make the window as tall as possible to see the Highest execution time of all Driver files (> 0)
    These are around 32 lines for my system, varies per system
6. Make a screenshot, place it to dropbox
7. Post screenshot
EDIT: 17:31:
8. Tell the values that you wrote on a piece of paper while watching LatencyMon running
-> min values
-> typical average values
-> recurring peaks
When talking about Latencies ... differentiate clearly between these two ....
But whatevery we talk about optimizing here .. its about the agility of the CPU to process a current task in time.
Its the delay / latency when the CPU was actually able to perform something .. sometimes sooner, sometimes
later because of an always changing system load caused by programs, services, interrupt requests.
But this latency has ABSOLUTELY NOTHING to do with the latency / Round trip time of audio transport
via PCIe / USB / Firewire / Thunderbolt between PC and Recording Interface.
This is always static and being reported by the ASIO driver to the DAW.
If you i.e want to play guitar over a virtual amp, then this delay between playing a string on guitar
and listening it then over phones connected to the recording interface only depends on the
- Round Trip time between Recording Interface  and PC (as being told by the ASIO driver)
- Processing time for the amp simulation (VST) in the DAW
You need to adjust the ASIO buffer size that the round trip time is best below 12ms.
With an UFX+ you achieve this i.e. with an ASIO buffer size of 256, better 128.
When we talk about system fine tuning and measuring with LatencyMon we only want to ensure, that the CPU is not busy with other things or delayed by energy saving, interrupt processing, bad drivers, unnecessary system load, so that there is always enough headroom to process audio in time.
Restart PC.
Login.
Do not start any application.
Wait until all programs started up.
Start LatencyMon and let it run for at least 10 minutes.
During the measuring do not start any applicaiton and avoid mouse movement as much as possible as this generates interrupts which a little influence the measuring.
7 (edited by ramses 2017-12-28 12:48:56)
This sounds as if you worked with your PC and did a measuring in parallel.
Then these measurings do not bring anything.
By this you can't see / measure the "basic load" that your system already has when no user application is running.
This is what we need to find out, to see how loaded your system is already by pure
- interrupt processing
- background programs
- programs started in the background by the Windows Task Planning Service
- energy saving which still might by enabled in the BIOS
- potentially wrong energy profile in use
- results of a certain delay of CPU core parking
Please read and try to understand my post #5 for what pupose this tool is to be used.
I tried to tell it in easier words.
A more thorough explanation you find on the Webpage of Resplendence Software:
http://www.resplendence.com/latencymon
Right, I posted both results before your response about how the test should be performed. I'll run a proper test shortly.
I ran a test for 47 minutes and took notes this time.
Minimum values on the "current measured interrupt..." was about 51-54.
Average values for "current measured interrupt..." was 89. Peak values were 103, 104, 109, 120
Average values for "highest measured interrupt..." were 156, 192, then 221. Minimum and Peak values were about the same.
Average values for "highest reported ISR routine..." were 191, 205 then 229. Minimum and Peak values were about the same.
Average values for "highest reported DPC routine..." were 301, 302, then 338. Minimum and Peak values were about the same.
Screenshot:
https://drive.google.com/open?id=1VGGlH … 7fGxdUZptl
Report Text:
_________________________________________________________________________________________________________
CONCLUSION
Your system appears to be suitable for handling real-time audio and other tasks without dropouts.
LatencyMon has been analyzing your system for  0:47:43  (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name:                                        THE-DANDELION
OS version:                                           Windows 10 , 10.0, build: 15063 (x64)
Hardware:                                             All Series, ASUS, ASUSTeK COMPUTER INC., Z97-A
CPU:                                                  GenuineIntel Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz
Logical processors:                                   8
Processor groups:                                     1
RAM:                                                  32709 MB total
CPU SPEED
Reported CPU speed:                                   40 MHz
Measured CPU speed:                                   1 MHz (approx.)
Note: reported execution times may be calculated based on a fixed reported CPU speed. Disable variable speed settings like Intel Speed Step and AMD Cool N Quiet in the BIOS setup for more accurate results.
WARNING: the CPU speed that was measured is only a fraction of the CPU speed reported. Your CPUs may be throttled back due to variable speed settings and thermal issues. It is suggested that you run a utility which reports your actual CPU frequency and temperature.
MEASURED INTERRUPT TO USER PROCESS LATENCIES
The interrupt to process latency reflects the measured interval that a usermode process needed to respond to a hardware request from the moment the interrupt service routine started execution. This includes the scheduling and execution of a DPC routine, the signaling of an event and the waking up of a usermode thread from an idle wait state in response to that event.
Highest measured interrupt to process latency (µs):   221.184340
Average measured interrupt to process latency (µs):   1.95460
Highest measured interrupt to DPC latency (µs):       219.904338
Average measured interrupt to DPC latency (µs):       0.912870
REPORTED ISRs
Interrupt service routines are routines installed by the OS and device drivers that execute in response to a hardware interrupt signal.
Highest ISR routine execution time (µs):              229.570
Driver with highest ISR routine execution time:       dxgkrnl.sys - DirectX Graphics Kernel, Microsoft Corporation
Highest reported total ISR routine time (%):          0.769161
Driver with highest ISR total time:                   Wdf01000.sys - Kernel Mode Driver Framework Runtime, Microsoft Corporation
Total time spent in ISRs (%)                          0.820035
ISR count (execution time <250 µs):                   51141474
ISR count (execution time 250-500 µs):                0
ISR count (execution time 500-999 µs):                0
ISR count (execution time 1000-1999 µs):              0
ISR count (execution time 2000-3999 µs):              0
ISR count (execution time >=4000 µs):                 0
REPORTED DPCs
DPC routines are part of the interrupt servicing dispatch mechanism and disable the possibility for a process to utilize the CPU while it is interrupted until the DPC has finished execution.
Highest DPC routine execution time (µs):              338.499250
Driver with highest DPC routine execution time:       nvlddmkm.sys - NVIDIA Windows Kernel Mode Driver, Version 388.59 , NVIDIA Corporation
Highest reported total DPC routine time (%):          1.217266
Driver with highest DPC total execution time:         Wdf01000.sys - Kernel Mode Driver Framework Runtime, Microsoft Corporation
Total time spent in DPCs (%)                          1.308012
DPC count (execution time <250 µs):                   62420775
DPC count (execution time 250-500 µs):                0
DPC count (execution time 500-999 µs):                13
DPC count (execution time 1000-1999 µs):              0
DPC count (execution time 2000-3999 µs):              0
DPC count (execution time >=4000 µs):                 0
REPORTED HARD PAGEFAULTS
Hard pagefaults are events that get triggered by making use of virtual memory that is not resident in RAM but backed by a memory mapped file on disk. The process of resolving the hard pagefault requires reading in the memory from disk while the process is interrupted and blocked from execution.
Process with highest pagefault count:                 none
Total number of hard pagefaults                       0
Hard pagefault count of hardest hit process:          0
Highest hard pagefault resolution time (µs):          0.0
Total time spent in hard pagefaults (%):              0.0
Number of processes hit:                              0
PER CPU DATA
CPU 0 Interrupt cycle time (s):                       436.324852
CPU 0 ISR highest execution time (µs):                159.766250
CPU 0 ISR total execution time (s):                   175.917471
CPU 0 ISR count:                                      48533312
CPU 0 DPC highest execution time (µs):                338.082250
CPU 0 DPC total execution time (s):                   284.288564
CPU 0 DPC count:                                      59076091
CPU 1 Interrupt cycle time (s):                       25.998036
CPU 1 ISR highest execution time (µs):                229.570
CPU 1 ISR total execution time (s):                   11.581408
CPU 1 ISR count:                                      802598
CPU 1 DPC highest execution time (µs):                338.499250
CPU 1 DPC total execution time (s):                   9.008490
CPU 1 DPC count:                                      831407
CPU 2 Interrupt cycle time (s):                       9.920523
CPU 2 ISR highest execution time (µs):                137.940
CPU 2 ISR total execution time (s):                   0.293146
CPU 2 ISR count:                                      1675041
CPU 2 DPC highest execution time (µs):                213.18450
CPU 2 DPC total execution time (s):                   4.290528
CPU 2 DPC count:                                      1836311
CPU 3 Interrupt cycle time (s):                       6.677155
CPU 3 ISR highest execution time (µs):                63.65850
CPU 3 ISR total execution time (s):                   0.043098
CPU 3 ISR count:                                      130504
CPU 3 DPC highest execution time (µs):                128.60550
CPU 3 DPC total execution time (s):                   1.347132
CPU 3 DPC count:                                      411474
CPU 4 Interrupt cycle time (s):                       5.288204
CPU 4 ISR highest execution time (µs):                0.85550
CPU 4 ISR total execution time (s):                   0.000004
CPU 4 ISR count:                                      19
CPU 4 DPC highest execution time (µs):                69.010
CPU 4 DPC total execution time (s):                   0.232438
CPU 4 DPC count:                                      105256
CPU 5 Interrupt cycle time (s):                       5.356392
CPU 5 ISR highest execution time (µs):                0.0
CPU 5 ISR total execution time (s):                   0.0
CPU 5 ISR count:                                      0
CPU 5 DPC highest execution time (µs):                68.7670
CPU 5 DPC total execution time (s):                   0.066146
CPU 5 DPC count:                                      23746
CPU 6 Interrupt cycle time (s):                       5.221563
CPU 6 ISR highest execution time (µs):                0.0
CPU 6 ISR total execution time (s):                   0.0
CPU 6 ISR count:                                      0
CPU 6 DPC highest execution time (µs):                68.75150
CPU 6 DPC total execution time (s):                   0.296499
CPU 6 DPC count:                                      110512
CPU 7 Interrupt cycle time (s):                       5.254919
CPU 7 ISR highest execution time (µs):                0.0
CPU 7 ISR total execution time (s):                   0.0
CPU 7 ISR count:                                      0
CPU 7 DPC highest execution time (µs):                68.42850
CPU 7 DPC total execution time (s):                   0.080041
CPU 7 DPC count:                                      25991
10 (edited by ramses 2017-12-29 11:34:13)
My absolutely lowest value for interrupt to process latency was 15 microseconds, your's you say was 51.
Thats a delta of ~35 microseconds.
The higest values for "this and that" are reported / visible from the GUI of the applications.
Its a good value for your system, but maybe a few things worth to check, see end of this post:
Here my values for comparison:
OS: Windows 10 , 10.0, build: 16299 (x64), this is the latest "Fall Creators Upgrade" from October 2017
BTW, you have a slightly older build of Windows 10, "Creators Upgrade" from March 2017
https://www.dropbox.com/s/29coidzamong0mo/2017-12-29%206.51%20Win10%20IRQ%20to%20User%20Process%20Latency%2001.png?dl=1
Here you can see the details per driver (you forgot to deliver this), which was their highest execution time.
This is extremely useful to check
- how many drivers are running in your system
- whether you have drivers in the system that run for too long on a core
Should not be higher than approx 250 microseconds for network and nvidia driver.
For most other driver it should be even much less, you can compare with the values of my system.
If you sort this output for DPC count (deferred procedure calls), which is actual driver activity after HW issued an interrupt,
then you can see which HW causes the highest interrupt load, simply by counting the amount of time the driver had been executed in the measuring interval.
https://www.dropbox.com/s/30qitbsxk6wb4zq/2017-12-29%206.51%20Win10%20IRQ%20to%20User%20Process%20Latency%2002.png?dl=1
The Report here:
https://www.dropbox.com/s/091pudfdsz94j … 3.txt?dl=1
1) BIOS - disable Energy saving
You could look at the BIOS energy settings, whether you really disabled everything in terms of energy savings
- no C-States, T-States, P-States
Some BIOSes have another way to prevent entering sleep states for the CPU to configure the highest possible sleep state, often you can select then
- C0 or C0/C1
- no C1E
What I did for my BIOS/System I documented in this Blog article, there is also a nice tabular, which sleep state introduces typicall how many latency (until a core is fully available again for the process scheduler of Windows).
https://www.tonstudio-forum.de/blog/ind … o-X10SRi-F
2) Disable CPU core parking
Whats also worth to check is to disable CPU core parking on Desktop machines, as the parking of a core of course also introduces latency for a system.
Steinbergs Cubase i.e. allows to activate Steinbergs own fine tuned energy profile, where CPU core parking and other things are automatically being disabled. I want to say by this, its fully ok to do this, shall you be anxious modifying this.
There is a good utility CPU core parking available, where you can fine tune per Windows Energy Profile
https://bitsum.com/parkcontrol/
- CPU core parking (how many % of cores to be parked)
- CPU Frequency scaling (how many % to reduce system clock)
Once you have fine tuned the energy profiles, then the tool tends to stay in the mini info tray.
You should then configure the tool not to start with Windows anymore and exit.
For a Desktop (without batterie) you only need to adjust the values for AC
For High Performance Energy profile we do not want to allow CPU core parking and no frequency scaling:
https://www.dropbox.com/s/kl6s3o8z5f558yp/Parkcontrol%20Win7%20H%C3%B6chstleistung.jpg?dl=1
For the Balanced Performance Energy profile I configured it for my system this way:
- 50% of cores parked (then Hyperthread cores become not used automatically)
- Frequency scaling to still achieve a minimum CPU clock of 2.5 GHz
  Its a little energy saving, but system / applications appear still to be responsive, like Firefox
  For my system this is 66% of turbo speed clock (3.8Ghz)
  You can check system clock by using tool CPU-Z: https://www.cpuid.com/softwares/cpu-z.html
https://www.dropbox.com/s/z9owjl22h0z38ay/Parkcontrol%20Win7%20Ausbalanciert.jpg?dl=1
For energy saving profile then maximum savings ...
https://www.dropbox.com/s/dpte2ehbcmor077/Parkcontrol%20Win7%20Energiesparmodus.jpg?dl=1
3) Windows 10 - Mini Apps
Windows 10 has a lot of processes for all this per default enabled Mini Apps.
If I remember right I had to right click to the ones enabled in the start menue to disable automatic upgrades.
And there is somewhere a configuration menue to disable some automatic running stuff.
Its maybe nice to watch for Smartphone junkies.
But for a recording system its not recommended to have instantly running application which access the internet.
As this adds a little to CPU load but also to interrupt load, as the internet is being accessed via the network driver.
11 (edited by ramses 2017-12-30 13:36:35)
I have an additional idea.
We did see with LatencyMon on an idle system, that your system should be able to run audio.
But a system might behave differently when being under load.
There is still a chance that you get Latency Spikes when your typical applications are running.
You can use DPC Latencychecker to get a nice graph over time.
http://www.thesycon.de/eng/latency_check.shtml
This result is with Cubase 9.5 and the new demo project running ...
EDIT: MADIface driver 0.9616, ASIO buffersize 128. Same results with ASIO buffersize of 32.
https://www.dropbox.com/s/cl2y8fjg3hxng4d/DPC%20Latency%20Checler%20140%20Win7%20Cubase%209.5.10%20Pro%20Demo%20Project.jpg?dl=1
12
I wish my notebook would behave like that...
13 (edited by ramses 2017-12-30 14:20:37)
I made another test which puts more load on my system.
The setup is documented here: https://www.tonstudio-forum.de/blog/ind … cks-de-en/
400 tracks of a Lee Ritenour Song where each of the tracks has 2 Cubase VSTs loaded.
ASIO Buffersize at 32 samples ..
CPU load on average: 30% (26 ... 38%)
16 GB DRAM in use out of 32 GB.
https://www.dropbox.com/s/3mj7acseos9dhd4/DPC%20Latency%20Checler%20140%20Win7%20Cubase%209.5.10%20Pro%20400%20Tracks%20Perf%20Test.jpg?dl=1
The same plus additional 2 VSTs: Superior Drummer 3 and Trillian, still with ASIO buffer size at 32 samples
CPU load on average: 40% (36 ... 49%)
https://www.dropbox.com/s/ftqrh34s3s5oa49/DPC%20Latency%20Checler%20140%20Win7%20Cubase%209.5.10%20Pro%20400%20Tracks%20Perf%20Test%2032%20samples%20buffer%20Superior%20Drummer%203%20%2B%20Trillian.jpg?dl=1
Ramses do you mind if I post my Latency monitor results here on this thread? So you could tell if my system is ok?
Good morning, I would suggest to open a new thread, as you have a different system and this here was 4y ago.
If you want you can give a reference to this thread by addining the URL of it.
No problem, I'll do it ASAP!
Thank you
Something cosmetic in LatencyMon? Or weirdness in the hardware?
