Topic: UCX analog outputs
Hello.
This my first message to this forum. Researching RME audio interfaces and thinking what should be the best for my case, a doubt comes to my mind. UCX - In a 8 speakers system, how could I config my set? I red a similar question where the use of 7/8 (headphone) was suggest for line out also. For those with experience in multichannel is that the only (or the best) way to route out 8 analogs channels with UCX? May be UFX is better? Is there some one working Ambisonic on UCX?
Re: UCX analog outputs
If you want balanced outputs, use the UFX... On the UCX, you would need a splitter cable, which would give you two unbalanced TS outputs. Not an issue on short to medium cable runs, but you would also lose the phones outputs.
