Topic: Axe-Fx II XL+ connection to RME FireFace 800 on S/PDIF
Everything works fine But I'm confused by the light very small glow of the indicator "HOST"
This is normal???
RME User Forum → FireWire & USB series → Axe-Fx II XL+ connection to RME FireFace 800 on S/PDIF
This is normal???
Connected to and working with a computer the LED should be off.
Working with a computer the LED be off. But as soon as I turn on Axe-Fx II XL+ "SPDIF" is turned on brightly and very weakly "HOST". Everything works fine with sound there's no problem. But I am am confused by the indicator "HOST". I use 1394 pci controller card "Texas Instruments". SPDIF" -Monster Cable!!! My RME FireFace 800 is absolutely new! It's problematic that this LED "HOST" is on??? When enabled Axe-Fx II XL+. Is there a way to reset the audio interface (RME FireFace 800) to factory settings?
Here I add photos:
Help me please...
P.S. The computer is on at this time.
Problem, it's not in Axe-Fx II XL+. I connected a landline DVD via SPDIF and RME FireFace 800 gives the same result ... How do I get back to the factory settings in RME FireFace 800???
So everytime the SPDIF LED lights up it shines over to the host LED? Optical only, or is the LED lit itself? Anyway, I wouldn't worry about that if everything works.
