Topic: What is the last driver for FF 800 for windows 10/64 Bit
now I have:
Driver date 15-12-16
Version 3.22
Hardware 2.77
Thank you.
RME User Forum → FireWire & USB series → What is the last driver for FF 800 for windows 10/64 Bit
now I have:
Version 3.22
Hardware 2.77
Thank you.
You can find this information very easily on the driver download page
http://www.rme-audio.de/en/downloads/dr … reface.php
TAB Firewire
-> Driver for Windows (XP SP2, Windows 7, 8, 10)
-> Windows 7 to 10 PnP Driver for Fireface 400, 800, 802, UCX, UFX, Version 3.123
19.07.2017 driver_fw_win_3123.zip
Latest Firmware is 2.77
Thank you
I have tried to instal Version 3.123, but he refused, the best is already installed can I install the 3.123 in another way?
I also think that in total-Mix 1.42 instal, I now have 1.40.
groeten
Your current driver version is 3.122. I see no reason why 3.123 shouldn't install. What exactly happens?
Matthias
I had no reason to install another driver, but I thought it would always be better to be up to date with the drivers, if this is the correct 3.122 Ok then.
Thank you for your advice
Sincerely.
Again: what exactly happens if you try to install 3.123? The message 'the best is already installed' is from Windows Update and not from our driver. It looks like you never tried to download it from our website and then install it.
I downloaded this file: Driver-fw-win-3123.zip, put it in a folder, then unzipped and tried to update the RME driver via devices, and referred to the folder it is in, but he does not take it .
will be allowed to try again
regards
louwe
This is a translation vie google.
That's not the way to install this - just run the file that says rmeinstaller...
Daniel , en Matthias.
I have now been able to install the driver, thank you very much for the advice and suggestions.
Kind regards.
Louwe
