Topic: FF UC - do I need to change card settings to 48 if I record at 48?
I have a ff uc which is set to 44.1
When I record at 48 do I need to change its settings to 48?
Thank you in advance.
RME User Forum → FireWire & USB series → FF UC - do I need to change card settings to 48 if I record at 48?
Usually the DAW changes the clock to 48 automatically.
But why you ask, simply look into the driver settings dialog when you have opened the DAW project, then you see it yourself.
