Topic: HDSPE Madi<>Ferrofish pulse 16 MX no lock
Ok, so i got some issues with this setup. The red error led is lit on the pcie card and i have no lock checking the dsp software, regardless of the fact the ferrofish is locked to the selected bitrate in the rme dsp software...and follows if i select another bitrate in the software. Ive played som tracks through logic aswell, it works. I can listen to selected tracks/channels through the ferrofish headphone jack.
Today i bought a 75 ohm wc cabel. Cant get the sync to work if i try to get the wc from the rme card....but if i do it the other way around, slave the hdspe madi against the ferrofish and it works....
Ive tried direct out´s ma2chbox with this setup and got green light on the rme hdspe...
Whats goin on?
