Topic: TotalMx front channel 3 and 4
I'm using a Fireface UC and recording 6 channels. From channel 3 to channel 8 are used for the recording.
However, from time to time "pad" button in channel 3 and 4 are turned into "+4"
This seems to increase the input sensitivity significantly and make the recording overloaded.
I don't know how to switch back to "pad" button visible.
Could you possibly help me with this problem?
Thanks a lot for your help!
Best regards,
Wookeun
Re: TotalMx front channel 3 and 4
Never heard of that. Driver version, TotalMix version, firmware version?
Thanks smile
TotalMix version is 1.22
How do I check the driver version and firmware version?
Sorry, I found the way to get the driver version
1.0.91.0
I have now updated the firmware, the driver, and total mix, but still have the same problem.
I don't understand why Total Mix changes the gain due to the input.
Could you possibly let me know how to go back to "pad" button from "+4"?
7
I can't, as this error is unkown. What is the exact firmware version that you see now in the Settings dialog, tab About?
Could it be that you have TM FX MIDI ports in use/assigned (F3), and this switching is caused by external DAWs or keyboards?
