Topic: UCX Fireface Power
Good Morning,
I'm buying this interface and I'm assaulted by doubts. Could the ucx work, without the power cable connected, even minimally? I do not want to have to be turning off and on every time I turn on the computer. If basic USB power were possible and only turn it on when needed, it would be fine.
I am worried about this fact because if not, I would be on all the time.
Thanks and best regards
Re: UCX Fireface Power
Sorry, USB power won't work. You can switch the device off on the back panel or you can you use a multiplug with a switch.
