Topic: BF Pro, 24/7 'On', is it safe or should I disconnect it?
It happen that I have my PC 'on' 24/7 for a certain reasons. Should I disconnect the BF for the night time or it is OK to have it always 'on'? Will it shorten BF lifespan or whatever?
RME User Forum → FireWire & USB series → BF Pro, 24/7 'On', is it safe or should I disconnect it?
I kept my non Pro Babyface on 24/7 in standalone mode for the last two years (at least). The only problem I encountered is that it sometimes loses its standalone routing from digital input to analog output, even though the Sync LED is on. I then have to power off/on and everything is working again.
It doesn't get warm or anything, but collects quite some dust from lying flat on the table.
