pianopictures wrote:Regarding the taskbar presence. I find myself popping this window from the tray, then doing a bit of something with the DAW, then remembering to check something in the "Settings", so to see it again I need to minimize the DAW window, as it stays beneath it. Not exactly conventional, and it may even happen that there is another layered window, so I need to minimize it too.
No. You simply need to click to the driver symbol in the Windows info bar and then it will be put into the foreground.
To give you an alternative.. There is a macro based solution available from a forum member, to open/close TM FX and the driver settings dialog. I put the information together, how to implement it, in this blog. https://www.tonstudio-forum.de/blog/ind … ndruck-DE/
pianopictures wrote:I know you can say that you can just pop it back from the tray - so, again, not the way I'm used to deal with the windows.
If N Windows are over your application, and you start to minimize all of them to finally see the desired information,
although you know that you need only to click with the left mouse button to the Driver Symbol in the infor bar,
then I regard your workflow as simply too complicated.
There is even another solution available, to use ALT-TAB, to scroll through the opened windows and bring the one to top which you need.
One should never be too old to learn a new trick
pianopictures wrote:And just the fact that some window stays secretly underneath all others, without giving me the indication of it - not exactly what I appreciate.
If you do not need this window anymore after making a change, then simply close it. Quite simple and straight forward.
Otherwise try to use this macro based method.
F1 to open close TM FX
ALT-F1 to open close driver settings dialog
You can choose also other keys like you want.
