Topic: Wiring 2 Hdspes
Hi guys, i'm using Madi Hdspe and just bought raydat because i needed aes ebu and Adat in&output.
It seems i can use it separately in total mix but i want to use it in same totalmix window, i meant, i want to monitor aes ebu in&out in Madi hdspe.
I have Lexicon PCM96 and lots of synths.
I will connect PCM96 to raydat through AES/EBU and other gears will be connected to MADI Hdspe.
But I don't know how to rout each other..
(Maybe i can use them together in DAW that's not my purpose.)
Is it impossible? or do i have to connect each other with cable?
Any suggestion will be nice.
Cheers,
Re: Wiring 2 Hdspes
There is no direct routing, the mixers are separate.
